Discovery II key fob programming
mco
auto: D2 po FL,TD5,ZF-4
#1 Příspěvek od mco » 28 srp 2024 19:01
Ahoj
ma niekto skusenost s programovanim kluca na DII cez Nanocom ked sa jedna o 18-miesny kod v tvare *XXXXXXXXXXXXXXX+*
Kluc je 443Mhz (EU auto), cez nanocom ho viem synchronizovat po stlaceni oboch tlacidiel (pri stlaceni jedneho to nefunguje - key signal not found), avsak pri key detect ho nenajde (ani pri jednom alebo oboch tlacidlach stlacenych)
Kluc nema 6-miestny kod na stitku vnutri na plosnej doske, je prilozeny len stitok s 18-miestnym kodom.
Postupoval som presne podla navovu od Nanocom (https://youtu.be/Zgjgt2ilEgE), pricom som pouzil 6miestny kod - znaky 2-7 z povodneho *XXXXXXXXXXXXXXX+* podla tohto navodu https://youtu.be/awzVBlgtv08?si=CYPWLVjBzZiTgXwu
key detect nefunguje
V Nanocom dokumentacii https://www.nanocom-diagnostics.com/upl ... 0Guide.pdf som nasiel:
KEY PROGRAM 6 DIGIT INNER CODE (Used on the Nanocom Evolution Mk 2)
This function allows you to program one or more keys on the 4 slots available (the suspension
plip is not used) by means of the 6 digit code printed on the label of the circuit inside the fob.
The code must be written in the desired slot and confirmed with the corresponding button. We
suggest using the first slot available. Once the code is inserted and confirmed the SYNC KEY
function is required to synchronize the fob’s rolling code.
KEY PROGRAM COMPLETE BAR CODE (not available on Nanocom Evolution Mk 2)
plip is not used) by means of the 18 digit bar code attached to the new keys. The code must be
inserted without the first 2 and the last 2 digits that normally are “*” or “?” and confirmed with
the Set button. We suggest using the first slot available. Once the code is inserted and confirmed
we suggest that you perform the SYNC KEY function to synchronize the fob’s rolling code.
Dokaze teda Nanocom programovat 18-miesny kod (extrahovanim znakov 2-7) alebo nie?
Petro
auto: 110Sw
Re: Discovery II key fob programming
#2 Příspěvek od Petro » 28 srp 2024 20:27
Original kluc pre Disko II bezne kodujem cez nanocom tak ako to je v navode. Uz sa mi stalo ze mi priniesli kluc co kupili z Ciny resp kluc pre Rover a ten nejde nakodovat resp nenasiel som sposob. Original kluc ma mat na nalepke ten kod, nic netreba extrahovat.
masar
tel.: 773968639
#3 Příspěvek od masar » 28 srp 2024 20:31
MadTom to myslím řešil, prý to taky nešlo jak mělo resp. neodpovídali ty pozice. Nevím jestli pro to existuje nějaký jiný pravidlo, která přesně část toho kódu to je nebo se to musí zkoušet. On ale určitě napíše :yes
Land Rover Discovery 2 Td5
#4 Příspěvek od MadTom » 29 srp 2024 07:30
Na webu jsou kalkulačky do excelu, který ten dlouhý kód přepočítají na krátký, já jsem to dělal tužkou na papíře a metodou pokus - omyl a šlo to. Těch čínských klíčů mi rukama prošlo asi 10, minimálně ve 4 různých provedeních. Když už to fungovalo, tak bylo důležité kód napsat dovnitř klíčku pro dalšího nešťastníka, co to bude řešit.
mco
#5 Příspěvek od mco » 29 srp 2024 13:36
MadTom píše: 29 srp 2024 07:30 Na webu jsou kalkulačky do excelu, který ten dlouhý kód přepočítají na krátký, já jsem to dělal tužkou na papíře a metodou pokus - omyl a šlo to. Těch čínských klíčů mi rukama prošlo asi 10, minimálně ve 4 různých provedeních. Když už to fungovalo, tak bylo důležité kód napsat dovnitř klíčku pro dalšího nešťastníka, co to bude řešit.
MadTom - nasiel som len excely, ktore to prepocitavaju kratky na dlhy kod:
https://docs.google.com/spreadsheets/d/ ... id=0#gid=0
https://landroverforums.com/forum/attac ... 0405-1.pdf
https://landroverforums.com/forum/attac ... 130409.xls
Mas nejaky hint ako to spravit reverzne? Podla vyssieuvedenych kalkulaciek, by to mal byt 2-7 znak z dlheho kodu, to mi vsak nefunguje
stiinek
auto: D2 Td5 2004
#6 Příspěvek od stiinek » 08 říj 2024 19:54
Koukal jsem teď do origo ruční T4 diagnostiky, a ta chce při programování 2 dlouhý kódy.
Předpokládám oba z origo štítku.
Pokud máš oba, můžu to zkusit zadat do auta a pak se podívat Nanocomem, jaký krátký kód vyčte.
Edit: Zkusil jsem ty kódy z obrázku, a v Nanocomu je: 4204D5, přesně podle těch návodů.
Disco2 Td5 2004
Nanocom Evolution (D2 + Td5)
