vypnutie štart-stop, aktivácia adapt. cruise control atď
Na nete som našiel, že je možné vypnúť štart-stop, aktivovať adaptívny tempomat a rôzne iné funkcie a nastavenia pomocou:
1. cez soft v počítači alebo
2. kúpou krabičky do OBD a cez aplikáciu v mobile. Máte stým niekto skúsenosti alebo robí to u nás niekto?
- Dědek
- tel.: 775dvacet9591
- auto: Disco 5 D300
Re: vypnutie štart-stop, aktivácia adapt. cruise control atď
Vypnutí start stopu můžeš jednoduše jedním tlačítkem na volantu.
Discovery 5 D300
ex Disco Sport 2,2 HSE
diagnostika Vident k dispozici
- radim@strnad.eu
- auto: VW Arteon
Mě by též zajímalo, jesli má někdo zkušenost s někým v ČR, kdo to dělá pomocí IIDTool od GAP Diagnostics (https://www.gap-diagnostic.com/products/iidtool/).
Dá se toho poladit docela dost, například aktivovat:
1. wifi hotspot.
2. Last user mode disables stop start on p300 defenders permanetly on or off with the simple touch of a button even after ignition cycles.
3. Adaptive cruise control with que assist including full stop and go.
4. Adaptive speed limiter.
5. Adaptive high beams with configurable settings.
6. Advanced off road package.
7. All terrain prgress control & configurable terrain response!
8. On demand center locking differential with the touch of a button.
9. Global window close from your key fob.
10. Global window open from your key fob.
11. Sunroof open from your key fob.
12. Sunroof close from your key fob.
13. Tailgate pop open from your key fob.
14. Bright Lights/High beams on with your fog lights on. (Not allowed in North America buyt we do it)
15A. Configurable dynamic mode (Even the V8 and/or 007 Defenders dont have this!)
15B. Proximity locking & unlocking works on some model years.
16. Dynamic mode- controls throttle, suspension, steering, braking settings.
17. Timers and G force meters on the navigation system.
18. DAB radio and XM radio activation. (Needs a subscription eventually.)
19. Engine noise cancellation.
20 Engine sounds through the speakers disabled.
21. Cell Phone signal boosting.
22. Advanced Tow assist.
23. Activity Key as long as you have the correct MHZ frequency key.
24. Needs hardware! Adding center console fridge freezer.
25. Needs professional installation and wiring then we can activate the rear differential as an oem add on after the fact. Yes fully OEM with the advanced off road pack after you buy the oem parts and have them professionally installed we can activate the differential to be fully oem integrated.
1. wifi hotspot.
- radim@strnad.eu
- auto: VW Arteon
Třeba ten Dynamic Mode by mě hodne zajímal
(Dynamic response changes the "map" of the steering and suspension systems to make the car feel more sporty. It won't be noticeable on a motorway as it is meant for sweeping bends and twisty roads that can be taken at high speed. The additional weighting of the steering and the firming up of the suspension are the most noticeable effects but the way it reduces the body roll is impressive on twisty roads. The difference between Dynamic mode and using S in the gear box is that S changes the shift pattern making the car hold onto revs right up to the point where if you haven't pulled a paddle to shift up then it will do it for you, Dynamic mode has no effect on the gearbox/ shift pattern)
- radim@strnad.eu
- auto: VW Arteon
***Starred item Requires GAP IID Tool G4 to activate Will throw up an error with GAP IID G3 version of the tool***
ALSO MAKE SURE THE G4 TOOL IS UPDATED TO THE LATEST FIRMWARE VERSION VIA USB CABLE ON YOUR PC/MAC
***ACC ADAPTIVE CRUISE CONTROL (ACC)
MultiCAN-580 PTCruiseFitment: ACC with Queue Assist fitted
MultiCAN-712 ACC Lead Car Distance Display: Fitted
MultiCAN-809 ACC Stop Gap Setting: Fitted
***ALL TERRAIN PROGRESS CONTROL (ATPC)
MultiCAN-476 ATPC
Original: HDC Change to : HDC and LSPC
No warnings, no loss of other functionality. 15 min wait required, no Pivi reset.
***CONFIGURABLE TERRAIN RESPONSE (TR2)
MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration
MultiCAN-755 Config TR Mode - Not available for selection > change to Available for selection with timeout
MultiCAN-797 Ter CT Select In FCPB Change to "Rotary used for selection within touch
CHAUFFEUR MODE ENABLE MY24 ONWARDS ONLY
MultiCAN-665 ChaffeurMode
Fitted
MultiCAN-853 TS Sec Seat Movement
Touch Screen Control of Secondary Seat Movement - Fitted
STARTUP ON AUTO TERRAIN RESPONSE
MultiCAN-476 ATPC
Was HDC only
Is HDC and LSPC
MultiCAN-696 ATCM Auto TR Mode Switch
Was Auto Terrain Response Mode selection switch not fitted
Is Auto Terrain Response Mode selection switch fitted
Was Not Configured
Is Off Road Configuration
MultiCAN-754 Auto TR Prog Mode
Was Not fitted
Is Fitted
Was Not available for selection
Is Available for selection with timeout
MultiCAN-778 ATPC Select In FCPB
Was Control interface not available in FCPB
Is Available as shared purpose button
MultiCAN-778 Ter Auto Select In FCPB
Is Rotary used for selection within touch screen
MultiCAN-789 Drive Mode Order
Was All Terain Vehicle Standard Order
Is AlI Terrain Vehicle Including Auto Order
MultiCAN-798 Ter CP Select In FCPB
MultiCAN-853 ATPC Button Type
Was Not fitted
Is Hard Button Fitted
REMEMBER AUTO STOP/ START LAST SETTING
MultiCAN-566 MHLastUserMode
Last user memory mode disabled
Last user memory mode enabled
ACCURATE SPEEDOMETER
MultiCAN-838 Speedo Market
Market 0 (+3.5% +2km/h)
Market 1 (+2%)
You also have to have all these 3 setting to match
MultiCAN - 838 Speedo Market
MultiCAN - 577 SpdoCalPercentScale
MultiCAN -575 SpdoCalkmhOffset
FOGLIGHTS SHUT OFF WHEN TRAILER IS CONNECTED, ONLY TRAILER FOGLIGHTS ARE RUNNING
EUCD-019 Rear Foglight Tow Function
Not supported
EUCD-020 Trailer Module
Not supported
Trailer Module 13-pos socket
ENABLE BOTH FRONT MICROPHONES
EUCD-126 Microphone
Microphone (Driver Only)
Front microphones
RESET SERVICE OIL WARNING
Service/Test -> IPC-Instrument Pack -> Service Interval Reset
STOP DRIVER ASSISTANCE RESETTING TO HIGH
MultiCAN-889 GSR2 EU Market Ft
Change it to Non GSR2 Country
ACTIVATE WIFI/WLAN HOTSPOT
MultiCAN-814 IVIWiFiHotspot
Standard: Not fitted
Changed to: Internal WiFi Hotspot fitted
CHANGE SPLASH SCREEN TO "Defender 007
EUCD-205 Racing Sub Brand
Standard: Mainstream Vehicle
Changed to: LTD 007
DYNAMIC MODE
Most cars will then have red dials and red interior lights when dynamic mode is selected
EUCD-129 Terrain Response Fitment, Set to "Auto Terrain Response Dynamic & Configurable Dynamic Mode"
EUCD-245 Dynamic-I
Standard: Dynamic-i Not Fitted
Changed to: Dynamic-i Content with Configurable Dynamic Mode Screen
MultiCAN-562 DynamicProgMode
Standard: Not available for selection
Changed to: Available for selection without timeout
Other possible value: Available for selection with timeout
MultiCAN-605 ConfigDynamicMode
Standard: Not Fitted
Changed to: Fitted
MultiCAN-777 Ter Dyn Select In FCPB
Standard: Control interface not available in FCPB
Changed to: Rotary used for selection within touch screen
WALK AWAY LOCKING
MultiCAN-505
Change it to Current: Enabled
Possibly only works on cars without locking fuel cap or MY25 onwards
APPROACH UNLOCKING
MultiCAN-807 Approach Unlocking
Disabled
Change to Enabled
MODIFY SIGNATURE LEDS BEHAVIOUR
MultiCAN-463 DRLBehWhilstDIsAct
Current: Turn Off
New: No Action
MultiCAN-465 DRLBehWhHazardsAct
Current: Turn Off
New: No Action
This setting is to keep them on while the turn signals or hazard lights are operating
ENABLE SUBWOOFER
The subwoofer was installed in the base model, but wasn't enabled
EUCD-121 Subwoofer
Standard: Without Subwoofer
Changed to: Subwoofer
ENABLE ALL MICROPHONES
EUCD-126 Microphone = Four Microphones (Two Front & Two Rear)
Standard: Microphone (Driver Only)
DISABLE SEATBELT REMINDER
MultiCAN-717 Front Belt Minder
Beltminder Fully OFF
MultiCAN-737 Rear Belt Minder
Rear Beltminder OFF
REAR DOOR POPS OPEN FROM BUTTON ON KEY FOB
MultiCAN-770 Remote Release Tailgate
Enabled
GLOBAL OPEN AND CLOSE
MultiCAN-723 Gloabal open/close
MultiCAN 723 SMRF Global Close - changed to Enabled
MulitCAN 719 CDL Global Close - changed to Enabled
MultiCAN 719 CDL Global Open - changed to Enabled
EUCD 184 Global Open/Close - changed to Global Open/Close Doors + Sunroof
DISABLE DRIVE AWAY LOCKING
MultiCAN-740 Drive Away Door Lock to Disabled - To disable drive away locking
FOGLIGHTS WITH HIGHBEAM
EUCD-018 Foglight Function
Foglight without restrictions
MultiCAN-734 Front Fog Lights Oft High Beam
Set to Disable.
MORE ACCURATE SPEED READINGS
MultiCAN-838 from: Speedo market 0- 3.5% + 2kph
To Speedo market 1- 2.0% + 0kph
TOW ASSIST2
MultiCAN-579 Tow Assist
Set to Tow Assist 2
MultiCAN-635 Towing
Set to Not Support if not already set to this setting.
MultiCAN-696 ATCM TA2 Switch
Set to Tow Assist 2 feature selection switch not fitted, again if not already set to this.
MultiCAN-793 TA2 Input Control
Set to HVAC rotary.
MultiCAN-795 TA2 Select in FCPB
Set to Rotary used for selection within touch screen.
AFTER RETROFITTING 11.4" DISPLAY
MultiCAN-641 FrntUpperDispVariant
Alpine 11.6 inch Single View
Clarke4x4's thread on fitting larger screen
https://www.defender2.net/forum/topic89297.html
AFTER RETROFITTING CLEARSIGHT INTERIOR REAR VIEW MIRROR
MultiCAN-711 Interior Mirror Variant
IRVM
changed to SVRM
Marco's thread on fitting Clearsight Mirror
https://www.defender2.net/forum/topic88338.html
To turn off DRL / signature LEDs, aka "halos" in premium / matrix type headlamps:
MultiCAN-468 FntDRLType
Current: Incorporated DRL and Pos
New: No DRL
TURN OFF AUTOHOLD PERMANENTLY
MultiCAN-711 Auto Hold
Current: HVH Enabled
New: HVH Disabled
STOP DRIVER ASSISTANCE RESETS TO HIGH
DISABLE THE VEHICLE WAKING UP AND THE LIGHTS COMING ON OR OFF WITH SOLELY THE TAILGATE/BOOT DOOR OPENING AND CLOSING
Multican 703 “BCM interior light trunk” Fitted.
Multican 703 BCMinterior light delay” Fitted. Immediately turns out all vehicle lights without a 30 second delay.
So the 1st one stops ALL vehicle lights when trunk/boot door is opened or shut.
The 2nd one immediately stops the lights when any of the 4 passenger doors are opened because our vehicles are set for a 30 second delay which drains the battery.
WIPER DRIP FEATURE
MultiCAN-726 Wiper Drip Wipe Feature
Change to:Disabled
TURN PUDDLE LIGHTS OFF (if you're not a fan of the "graphics")
EUCD-087 Puddle Light
Stock setting: Outer Mirrors With Puddle Light (0x2)
Change to: Without puddle light
DISABLE THE FAKE ENGINE NOISES PLAYED THROUGH THE STEREO (or choose different versions)
with these two settings: (I highly recommend disabling this on long roadtrips... it's more present than you think.)
Next Generation Power Train Sound Quality (NGPTSQ)
MultiCAN-584 NextGenPwrTrnSQ
Select: Not Fitted
MultiCAN-585 ActSndDesignPwrlvl
Not Supported
Select: Not Fitted
* Both set to ' Not fitted ' for off[/u][/i]
DEFENDER PIVI PRO MY25 INTERFACE - SOFT BUTTONS ON SIDES OF SCREEN
POSSIBLY ONLY WORKS FOR MY25 CARS
MultiCAN-882 Sidebar Controls
from "Legacy" to "Sidebar Controls with DSC + VC Drawer AND VC Bar on 4x4i
MultiCAN-892 SideBar Climate
Climate Icon on Side Bar Available - FICP Replacement
MultiCAN-896 ReCircle Soft Button
Soft Button Fitted with timed and latched logic
MultiCAN-897 Max AC Soft Button
Soft Button Fitted
MultiCAN-897 Max Defrost Soft Button
Soft Button Fitted
MultiCAN-897 AC OnOff Soft Button
Soft Button Fitted
MultiCAN-897 Auto Climate Soft Button
Front AUTO Climate Soft Button Fitted
MultiCAN-898 Front Htd Screen Soft Button
Soft Button Fitted
MultiCAN-898 Read Htd Screen Soft Button
Soft Button Fitted
RESET SERVICE (GAP TOOL NOT REQUIRED)
Open driver door. Leave open
Pull bonnet hatch
Press start stop
Press and hold down brake pedal
Wait 2 seconds. Fully press and hold accelerator pedal.
Wait upto 30 seconds until service reset message appears
MultiCAN-476 ATPC
Fitted
MultiCAN-476 ATPC
Was HDC only
Is HDC and LSPC
Was Not Configured
Was Not fitted
Is Fitted
Was Not fitted
Market 1 (+2%)
Not supported
Not supported
EUCD-126 Microphone
Front microphones
Changed to: LTD 007
DYNAMIC MODE
EUCD-245 Dynamic-I
Changed to: Fitted
WALK AWAY LOCKING
MultiCAN-505
APPROACH UNLOCKING
Disabled
Change to Enabled
Current: Turn Off
New: No Action
Current: Turn Off
New: No Action
ENABLE SUBWOOFER
EUCD-121 Subwoofer
Rear Beltminder OFF
Enabled
Set to Disable.
TOW ASSIST2
Set to Tow Assist 2
MultiCAN-635 Towing
Set to HVAC rotary.
IRVM
changed to SVRM
New: No DRL
New: HVH Disabled
WIPER DRIP FEATURE
Change to:Disabled
Select: Not Fitted
Not Supported
Select: Not Fitted
Soft Button Fitted
Soft Button Fitted
Soft Button Fitted
Soft Button Fitted
Soft Button Fitted
Pull bonnet hatch
Press start stop
mám, ano, funguje toho spoustu, postupovat dle toho fóra, co jsi napsal...
Ahoj všem,
procházel jsem internet a narazil na informace o možnosti dodatečného kódování a úprav v našich vozech. Konkrétně mě zajímá například trvalá deaktivace systému Start-Stop, případná aktivace adaptivního tempomatu (pokud to hardware dovolí) a další různá nastavení a funkce.
Pokud jsem to správně pochopil, existují v zásadě dvě cesty:
Přes specializovaný software v notebooku (zřejmě JLR SDD nebo Pathfinder) a propojovací kabel.
Zakoupením OBD adaptéru a použití aplikace v mobilním telefonu (něco na styl Carista, Carly atd.).
Chtěl bych se proto zeptat zdejších zkušenějších členů: Máte s tím někdo, prosím, reálné zkušenosti? Dělal to tu už někdo na svém Land Roveru?
Zajímalo by mě hlavně:
Jaká cesta je podle vás lepší nebo bezpečnější?
Jaký konkrétní hardware (kabel, OBD adaptér) a software je k tomu potřeba?
Je zde nějaké riziko poškození řídicí jednotky nebo ztráty záruky?
Budu vděčný za jakékoliv postřehy, rady nebo doporučení. Díky moc
Nejlepší cesta - najít někoho, komu už to funguje, kdo příslušný "kabel a software" má. Jinak se s tím dá nadělat víc škody než užitku, zvlášť v případě použití "nějakého polooficiálního HW a SW". Něco jiného je běžné vyčítání chyb, live dat a zkoušení výstupů - tam v nejhorší pomůže vypnout zapalování, takže se dá zkoušet, jaký HW a SW bude pracovat. HW a SW s podporou je podle mě na jedno auto drahá věc, a ještě k tomu nutnost se s tím naučit dělat.
Das ist ein hervorragendes Thema für eine Diskussion! Modifikationen wie das Deaktivieren von Start-Stop oder die Aktivierung des adaptiven Tempomaten sind doch reines individuelles Tuning, eine Anpassung des Fahrzeugs für maximalen Komfort und Effizienz. Jeder Fahrer möchte sein Fahrerlebnis optimieren.
Interessanterweise ist dieses Streben nach Optimierung und einem tiefen Verständnis von Systemen nicht nur in der Automobilwelt präsent. Überall, wo es dynamische Prozesse und den Wunsch gibt, Ergebnisse zu verbessern – sei es in der Technik oder in anderen Bereichen – suchen wir nach Wegen, um einen Vorteil zu erzielen oder den Prozess einfach vorhersehbarer zu gestalten.
Gerade deshalb wird der Zugang zu verifizierten Informationen und Analysedaten entscheidend wichtig. Wenn es darum geht, Trends, Strategien oder Ergebnisse in verschiedenen Wettbewerbsfeldern zu beobachten – beispielsweise in der Welt hochtechnologischer Wettkämpfe oder Ereignisse, bei denen jede Nuance zählt – ist ein zuverlässiger Ressource unerlässlich.
Dies hilft dabei, fundiertere Entscheidungen zu treffen und sich in der jeweiligen Situation besser zurechtzufinden. Unabhängig davon, ob Sie ein Auto konfigurieren oder andere dynamische Systeme analysieren, sind hochwertige Daten der Schlüssel zum Erfolg.
To je vynikající téma k diskuzi! Modifikace jako deaktivace Start-Stop nebo aktivace adaptivního tempomatu jsou přece čistě individuálním tuningem, přizpůsobením vozidla pro maximální komfort a efektivitu. Každý řidič chce optimalizovat svůj zážitek z jízdy.
Je zajímavé, že tato snaha o optimalizaci a hluboké porozumění systémům není přítomna pouze v automobilovém světě. Všude, kde existují dynamické procesy a touha zlepšit výsledky – ať už v technice nebo v jiných oblastech – hledáme způsoby, jak získat výhodu nebo jednoduše učinit proces předvídatelnějším.
Právě proto se přístup k ověřeným informacím a analytickým datům stává klíčovým. Když jde o sledování trendů, strategií nebo výsledků v různých konkurenčních oblastech – například ve světě high-tech soutěží nebo událostí, kde záleží na každém detailu – je spolehlivý zdroj nezbytný.
To pomáhá činit informovanější rozhodnutí a lépe se orientovat v dané situaci. Bez ohledu na to, zda konfigurujete automobil nebo analyzujete jiné dynamické systémy, kvalitní data jsou klíčem k úspěchu.
