manual-defender,range,series,discovery,freelander
klabus
tel.: 774106760
auto: LR Discovery
#1 Příspěvek od klabus » 27 led 2012 14:33
Manualky,třeba se vám něco hodí....
http://daemon4x4.org/portal/downloads.php?dcid=6" onclick="window.open(this.href);return false;
DISCO 300TDi
K.O. TEAM
Leoš
Re: manual-defender,range,series,discovery,freelander
#2 Příspěvek od Leoš » 27 led 2012 18:45
Land Rover - manuály ke stáhnutí
http://lrparts.net.ru/" onclick="window.open(this.href);return false; - online katalog náhradních dílů
http://www.dap-inc.com/catalog/series.pdf" onclick="window.open(this.href);return false;
http://topix.landrover.jlrext.com/topix/i18n/index" onclick="window.open(this.href);return false; - uživatelské příručky
http://www.landroverweb.com/landrover/p ... r-manuals/" onclick="window.open(this.href);return false;
http://www.landroverresource.com/" onclick="window.open(this.href);return false;
http://www.landroverresource.com/docs/LR_VIN_Coding.pdf" onclick="window.open(this.href);return false; - VIN LR
http://www.landroverresource.com/docs/L ... _Codes.pdf" onclick="window.open(this.href);return false; - barvy LR
http://www.hanys.net/Defender_Workshop.pdf" onclick="window.open(this.href);return false; - LR Defender 1999-2002
http://www.ownerinfo.landrover.com/extf ... /index.jsp" onclick="window.open(this.href);return false;
http://www.awdwiki.com/en/land+rover/" onclick="window.open(this.href);return false; - pohon 4x4
http://www.uloz.to/hledej/?q=land+rover" onclick="window.open(this.href);return false; - katalogy na LR
http://pdftown.com/Pdf-eBook/Land-Rover.html" onclick="window.open(this.href);return false;
http://carservicemanuals.blogspot.com/s ... nd%20Rover" onclick="window.open(this.href);return false;
http://www.landrover.vlothuizen.nl/brochures.html" onclick="window.open(this.href);return false; - brožury LR
http://landroveroneten.com/index.php/ge ... r-manuals/" onclick="window.open(this.href);return false;
http://www.landroversonly.com/forums/f5 ... oad-17678/" onclick="window.open(this.href);return false;
http://www.muddyoval.com/articles/manuals/index.htm" onclick="window.open(this.href);return false;
http://www.ocs.cz/CD/etm99.zip" onclick="window.open(this.href);return false; - manual na Range Rover P38
http://www.uloz.to/6986221/manual-defender-td5-pdf" onclick="window.open(this.href);return false; - uživatelský manual na Defendra TD5
http://defender110.nightmail.ru/" onclick="window.open(this.href);return false;
http://www.landroverforum.cz/data/priruckafre1.pdf" onclick="window.open(this.href);return false; - uživatelský manuál Freelader TD4 v češtině 01
http://www.landroverforum.cz/data/priruckafre2.pdf" onclick="window.open(this.href);return false; - uživatelský manuál Freelader TD4 v češtině 02
http://www.landroverforum.cz/data/audiosestavafre.pdf" onclick="window.open(this.href);return false; - audiosestava Freelander TD4 v češtině
http://autorepman.com/cs/land-rover/143 ... ander.html" onclick="window.open(this.href);return false; - dílenský manuál na Freelander 2001-2004
http://www.myfreelander.co.uk/" onclick="window.open(this.href);return false; - informace o poruchách na Freelanderu
http://green-oval.com/data/lr/" onclick="window.open(this.href);return false;
http://www.uloz.to/4412722/land-rover-d ... cka-cz-pdf" onclick="window.open(this.href);return false; - Land Rover DISCOVERY II uživatelská příručka CZ
http://www.ulozto.cz/7535650/microcat-l ... 1-2011-zip" onclick="window.open(this.href);return false; - Microcat.Land.Rover.01.2011
http://www.difflock.com/downloads/DIFFL ... ng-Kit.pdf" onclick="window.open(this.href);return false;
http://www.repairmylandrover.co.uk/download-section" onclick="window.open(this.href);return false;
http://legionlandrover.com/index.php?sec=3" onclick="window.open(this.href);return false;
http://www.uloz.to/11398060/manual-range-rover-pdf" onclick="window.open(this.href);return false; - Range Rover P38 - uživatelský manual
http://www.uloz.to/5657263/land-rover-d ... cka-cz-pdf" onclick="window.open(this.href);return false; - LR D2 - uživatelská příručka
http://www.legionlandrover.com/manuales ... 0rover.pdf" onclick="window.open(this.href);return false; - Range Rover 2,4VM - servisný manuál
Naposledy upravil(a) Leoš dne 27 led 2012 19:30, celkem upraveno 1 x.
Leoš
#3 Příspěvek od Leoš » 27 led 2012 18:46
Land Rover - manuály RAVE
Manulály RAVE na Uložto.
Discovery II
Freelander 01
http://ulozto.cz/5194859/rave01.iso" onclick="window.open(this.href);return false;
New Range Rover
Range Rover
Defender
http://ulozto.cz/5205142/rave02.iso" onclick="window.open(this.href);return false;
Freelander
Discovery I
Range Rover Classic
http://ulozto.cz/5205138/rave03.iso" onclick="window.open(this.href);return false;
http://www.ulozto.cz/5624603/microcat-l ... 6-2010-zip" onclick="window.open(this.href);return false;
Leoš
#4 Příspěvek od Leoš » 27 led 2012 18:47
Zkratky systémů u LR
ABS - Anti Lock Braking Systém, systém kol zabraňující zablokování kol při brždění
ACE - Active Cornering Enhancement, systém vyrovnávání bočního náklonu karoserie
ASH - Anti Shunt Control, systém brždění motorem bez zablokování kol
CBC - Cornering Brake Control, kontroluje průjezd zatáčkou při brždění (součást DSC)
CDL - Central Door Locking, centrální zamykání dveří
DSC - Dynamic Stability Control, zajišťuje dynamickou stabilitu vozidla při průjezdu zatáčkou
DSP - Digital Signal Processing, slouží k digitální úpravě zvuku audiosoustavy
EBA - Elektronic Brake Assistant, brzdový asistent při nouzovém brždění
EBD - Elektronic Brake Distribution, elektronické rozdělení brzdné síly mezi nápravami
EKA CODE - Emergency Key Acces Code, kod pro nouzový přístup do vozidla
ETC - Elektronic Traction Control, elektronická kontrola trakce zabraňuje prokluzu kol
GPS - Global Position Systém, navigační systém
HDC - Hill Descent Control, kontrolované sjíždění svahů, konstatní rychlost kolem 9,5 km/h
SLS - Self Leveling Suspension, systém udržující stálou výšku pérování vozu
SRS - Supplementary Restrain System Airbag, předpínače bezpečnostních pásů
TMC - Traffic Management Channel, kanál na kterém se nachází informace o dopravě
Leoš
#5 Příspěvek od Leoš » 27 led 2012 18:48
Výběr barev na LR na simulátoru - http://www.paintman.co.uk/paint-colour- ... 0-110.html" onclick="window.open(this.href);return false;
Gobey
tel.: +420603440581
auto: Defender
#6 Příspěvek od Gobey » 27 led 2012 22:00
Dobrá práce :). Admini by to mohli upíchnout nahoru.
VencaZE
tel.: 602 550 993
auto: 110HT, S2A 88, G66
#7 Příspěvek od VencaZE » 31 pro 2012 11:11
Další online katalog náhradních dílů, něco jako výše uvedený http://lrparts.ru :
http://landroverparts.roversnorth.com
Robo H
tel.: 0904 528 713
auto: LR Disco2 Td5
#8 Příspěvek od Robo H » 02 led 2013 09:02
Leoš píše:Zkratky systémů u LR
CDL? Nemá to byt náhodou Central diferential lock? - uzávera medzinapravy?
LR Disco 2 , 1999 Td5 ; Gaz 69M 1965
