RR L322 3.0 Td - olej rozvodovka
Zdravím, chci se zeptat, jestli i do rozvodovky patří Dextron III. Děkuji.
- Dendy
- tel.: 608894sest88
- auto: MGF/TF, Jag, RR L322
Re: RR L322 3.0 Td - olej rozvodovka
Tohle je vykopírované RAVE k L322:
Engine oil - Td6
Use a longlife or any fully synthetic 0W/40 oil meeting
specifications ACEA - A3/B3; CCMC - G5/PD2; API
- SJ/CD and having a viscosity band recommended
for the temperature range of your locality.
Engine oil - V8
Use longlife or any fully synthetic 0W/40 oil, meeting
specifications ACEA - A3/B3; API: SJ, ECII and
having a viscosity band recommended for the
GM Automatic Gearbox oil
Use only Texaco ETL-7045E.
ZF Automatic Gearbox oil
Use only Esso ATF LT 71141.
Transfer box
Use only Castrol BOT 26 FMB 1
Front and rear differential
Use oil to specification 75W/90 API GL5.
Power steering
Use only Texaco Cold Climate PSF 14315 fluid
Air Conditioning
Use lubricating oil Nippon Denso ND-8.
General Greasing
Use Multipurpose Lithium Base Grease N.L.G.I.
consistency No. 2.
Engine oil - Td6
Engine oil - V8
Transfer box
Power steering
Air Conditioning
General Greasing
consistency No. 2.
